explorer 5.0 supercharged? | Ford Explorer Forums
Mass
1996 Limited
does anyone know if a supercharger kit from a mustang would fit on a explorer with a 5.0 my buddy has 1 cheap. thanks
no, first you have to change all your accessory brackets over, then i doubt the A/C will work after. With some kits you might have to clock the blower outlet to the throttle body or get the 45deg 94/95 inlet adapter. Thats assuming it'll fit in the same physical space depending if its a 87-93 or 94/95 setup. Umm yea so its not a direct bolt on :D
Bottom line is if he is willing to let you experiment go for it
