Explorer 93 ecu pinout chart | Ford Explorer Forums
Eduardox88
93 explorer xlt
Hi everybody,
I'm Looking for the ecu pinout chart of an explorer 93. My problem is Im swapping my bronco II 2.9 87 with a 93 4.0ohv and I'm in the process of cleaning the wiring harness (removing abs, headlight wirings) because I will use my stock wiring.
In the process I found a wire that goes from ECU pin 17 to abs ECU plug and also to the big plug that go inside the cabin.
I think is for MIL light( check engine light) but not sure.
Someone that can help me?
tan red is mil wire
roscoe
ECU Pinouts / EFIDynoTuning
EEC-IV is at the top of the page.
You will need the 5 letter "strategy" code off your PCM to find the correct pinout for your model/year/trans etc.
Isn’t it usually on a sticker on the ECM itself?
This is not an Explorer ECM but I think the code you need is on a sticker similar to this one up at the top
Yours is eec-iv not eec-v but I think it’s the bigger numbers/letters
Yep that's it, the big letters. Some codes do have a number or two.
Oops, Sorry wrong link. That was for the 5.0L cars.
Here ya go: Ford EEC-IV
