Explorer Hub Replacement? | Ford Explorer Forums
91X&67STANG
San Diego, Ca
91 x EB 4x4
blew my front driverside bearing the other day along with my rotor and hub.
my hub when removed bearing went into pieces and on the spindle side the plastic/ pot metal piece that slides on is now cracked. the washer that holds everthing in place was welded on by the heat and after i pried that off i noticed that the washer no longer has the groves to slide on on the axle side.
i took all the 4 X4's pieces that were needed off. the plastic/pot metal piece and the enternals of the outer hub off for now because this is my dailey driver.
i need help to find out what parts i need and what the heck these items are called. and the best place to get them ... cheap!
thanks rich
It's cheaper to replace the old auto hubs with manuals. Plus the manuals are more reliable. Search this site for "manual hub conversion" and "manual hubs" and so forth and you'll find tons of information on where to buy manuals, and how to convert your auto hubs to manuals.
