factory sub | Ford Explorer Forums
factory sub
Bionic4.0
bville fl
'92 XLT
does any know if the wiring is already there and just tucked away for a factory sub?
Where are you locating the sub? I'm in the process of building a box to fit under the rear passenger seat to fit (1) 10" sub with the amp under the center seat. All will be attached with a plug so it can be easily removed to get access to the jack behind the seat.
Here is my setup:
wow thats an impressive set up, they didnt leave us much space t work with for this. Are your boxes sealed? from my (some what limited) understanding of subwoofers, the box needs a certain amount of enclosed volume to function properly, is this really important and did you take that into consideration? I had to take a break from working on the truck to paint the kitchen but i will post my own photos when i'm done
Boxes are sealed and have the right amount of air space for the subs. The back side of the box is made from fiberglass so it is formed to the curve in the back wall. They are about 5-6" deep. Plus they are just 8" woofers.
