Tedybear
- March 7, 2016
- Fulton, NY
- 1995 Ford Explorer
Hiya again!
Thanks to the team guys that are helping me with that engine noise. (I will of course check in manually sense my notice function isn't functionally)
Okay. Picked up a set of replacement fobs from an ebay seller. (went with one store with a very high rating)
Programming instructions:
Turn key to "on-off" 5 times within 10 seconds and finish the 5th cycle leaving the key in the run/on position.
Should hear locks cycle.
Push button on remote(s) to program.
All doors must be closed (verified by making sure interior lights are all off), and foot off the brake while doing this. (This explorer is a 5 speed stick shift)
Here's where this goes pear shaped.
Do the key cycle. For some reason my door locks cycle when I first try turn the key to the 'on' position. (I've never owned an explorer...is this normal?) It powers the locks each time I do this. Heck, after 2 or 3 times the passenger side door power lock sounds like a 50 year old adding machine going "Clunk Clunk Clunk".
So I tried this several times, even went to 6,7,8,9 rotations. I can't get the system to receive the new fobs. It's supposed to cycle the locks on it's own with the key in the 'run/on' spot. Issue is that it cycles the locks each time I rotate that key, and I've waited a few moments after turning the cylinder to the 'on' spot in case it does it again without rotating the key. No dice.
Of course not to be outdone:
I found the cylinder itself is totally screwed. I forgot to insert the key, and it free spins regardless if the key is inserted or not. (tried it that way, without the key just for fun. Same exact result)
Now the guy I purchased this from said to start the truck: Insert key (Duh) Press the unlock on the fob again, and then the truck will start. This again makes no sense.
Not to be outdone:
Open the door with just the key: Hear the alarm "Beep Beep Beep". The last owner claimed "That's the alarm warning. The truck won't start until you press the unlock on the fob".
I hear that same beep sound as soon as you do start the truck! And it stays beeping.
My gut feeling (yeah, like that's been accurate lately) The key cylinder is hosed and responsible for most of this.....
Any ideas? This truck has more quarks then I expected.
S-
Not to be outdone:
S-
