First my windshield washer stopped working and now the wipers dont work... | Ford Explorer Forums
firebird4life
What could it be? I replaced the multifunction switch last year due to problems with the turn signals...so Im not sure if it could be out already. For some reason I think its switch related because why else would I have problem with the washer and wiper only weeks apart. Is there anyway to take to the switch out and bridge the wires between the wiper harness to test the motor?
Can it be the motor?...but if it was this...wouldnt they go out only one side at a time?
I check the fuse...I believe its #16...a 30amp fuse and it seemed to be fine.
Please help me!
The wipers run on one motor if I remember correctly, did you check the relays?
Well my squirters quit workin over a relay being loose. Mine are under the air filter box just a small box with 4 or 5 relays.
Have someone turn the wipers on and see if you can hear the relay click on
