SteveH - Colo
- November 7, 2008
- Colo Springs, CO
- 92 Sport 5 speed
A buddy gave me a '92 Explorer that was hard to shift in the forward gears and made horrible grinding sounds going into reverse. The rest of the truck was perfect.
The mechanic's diagnosis was 'leaky slave cylinder' - which was not true - it was dry. I surmised that the clutch was not fully disengaging, based on pedal travel measurements and other factors. Ford sure uses a lot of cheap plastic junk in the clutch actuating system.
The clutch master cyl. actuating rod is fixed-length on this truck - not adjustable. So, I bought an adjustable clutch rod for a '86 Ford pickup (DORMAN Part # 14570 - from NAPA), which is too short. I then removed and cut the factory rod in half. I drilled and welded in a section of the threaded rod, and used the threaded end-link for the pedal end. You have to be careful not to cut in the area where the neutral safety switch lives. I made the minimum length equivalent to the old fixed-rod length - 8 3/4". I installed it, and then adjusted it to be about 5/8" longer than stock. The clutch pedal now sits higher, for what that's worth.
In the end, for $10.49 and 4 hours of fab time, the truck now shifts perfectly. There is no 'drop in' adjustable clutch rod for this truck (that I could find), but fabbing one sure beat dropping the tranny and replacing all the parts and hoping that would fix it.
I can't post photos of the fab job, but have some, if anyone replies with their email address - I will send them.
Steve
Steve
