LONO100
- March 23, 2011
- Bay Area CA
- 03 sport trac XLT
Hi all, i recently ran into a fuel pump issue and wanted some opinions. for the past few weeks, there would be some days that i would jump into my truck, turn the key, and get no turnover. then i would come back a few hours later and it would fire up no problem. i then noticed that every time my truck wouldn't turn over, i dont hear the fuel pump buzzing so i figured that it was a fuel pressure problem. the funny thing, is that i never get this failure when im driving, or anywhere else, it always happens in the morning when i first try to fire up my truck.
now, it doesn't fire up at all. i got a fuel pressure gauge, tapped into the fuel rail via the schraeder valve and turned the key to the on position and got 0 pressure. to make sure i don't replace the fuel pump needlessly, i popped the fuel pump relay and took it to work where i have a power supply. i then hooked 12 volts to it and could not get the relay to click over. i also measured no continuity and OL ohms. i figured, "yes, it's just a bad relay."
i then went to autozone and got a replacement relay, brought it back to my shop and ran the same test to make sure it was working correctly. sure enough, i was getting it to click over once i ran 12 volts, and i got proper OHM measurements. (2 mohms).
here's the weird part: i ran the same test on the old relay, and i was able to get it to click over and show continuity. my question is, has anyone ever seen this flaky of a relay before, and if so, is there something within my truck's electrical system that is causing the relay to fail? anyone ever run into this flaky of a relay?
any opinions on this would be really appreciated.
