prozachappy
- April 28, 2002
- SoCal
- 94 explorer...sportster
Trying to replace my FPR and O2's on my 1994 2wd Explo. I'm only interested in OEM motorcraft parts, and always order from www.rockauto.com because you can usually find everything you need and their prices on OEM MotorCraft parts are usually about 1/2 the price you'll pay anywhere else. Problem is they list all these ford part# and options for a FPR for my 94. I'm pretty sure they're all going to be the same part, just succeeding numbers for parts made the following year ie..90TF, 91TF, 93TF and so on. So all should be good for 91-94 explo's right.
For the O2's...I'm not sure because there was a difference between EGR systems that were CA emissions and non CA. Mine is CA emissions with an EGR tube coming off the exhaust manifold. Not sure if that will effect which O2's I need. Plus they list one as "heated" oxygen sensor.
I really don't think it's going to matter, but I thought I'd check and see if anyone here had similiar issues.
If your familiar with FM part numbers or know what is what please help!
if your just going to take a guess...don't confuse me more
thanks, Jason
Fuel Pressure Regulator
Motorcraft part #CM4685
90TF-9C968AA Fuel Pressure Regulator {#FOTZ9C968A}
or #CM4723
91TF-9C968AA Fuel Pressure Regulator {#F1TZ9C968A}
or #CM4750
93TF-9C968AA Fuel Pressure Regulator {#F3TZ9C968A}
O2 Sensor
Motorcraft part #DY619
F09F-9F472CA Oxygen Sensor {#F09Z9F472C}
or #DY733
F1UF-9F472CA,F3UF-9F472CA Heated Oxygen Sensor {#F4UZ9F472C}
or #DY713
F2AF-9F472CA,F39F-9F472CA Heated Oxygen Sensor {#F39Z9F472C}
thanks, Jason
or #CM4723
or #CM4750
O2 Sensor
or #DY733
or #DY713
