For Reference: M5OD Bellhousing Bolts to 4.0 OHV V-6 | Ford Explorer Forums
fast_dave
East Bay - Nor Cal / PRK
'98 Spt 4.0 OHV 5 spd 4x4
The 4.0 OHV is a GERMAN engine - thus METRIC BOLT SIZING between the M5OD 5-Speed Manual Transmission Bellhousing and the 4.0 OHV V-6 Engine Block.
The Flange Bolt Size/Thread you need is M10 - 1.5
I had to find two the two bottom bellhousing bolts that are parallel to the ground.
They are M10 - 1.5 X 80MM Long (measured from base of the flange to the end of the bolt)
Hope this helps someone in the future.
NOTE: If someone knows the shorter lengths for the other bell housing bolts, please add them to this thread!
