Wanted - ford aftermarket key fob HELP! | Ford Explorer Forums
Wanted ford aftermarket key fob HELP!
Parts or services wanted
ninety9sport
Hopewell Jct., NY
99 Explorer Sport
ok heres the deal. i have a sport with a ford aftermarket key less entry system. i went to ford to see if they can get a new key fob for me. the one i have for my sport is discontinued. i tried newer styles but nothing works with the old ford system. i even went on a website that said they had ones that worked. ordered them, tried programing them and they didnt work. im gonna need a used one or used one. please help! if anyone has any used key fob with part number goh3bfm2497 let me know. id like one or 2 in good condition with the key loop still together
that is very weird. i had a 03 sport trac that was missing both of them, and i used one from my 07 ranger and it worked. i dont know how much different they are however
those ones dont work. i tried. its a ford after market alarm system that they dont make anymore. i need ones that look like mine or ill settle for a case at this point
'After Market' words in my experience doesn't go with 'Ford'.
i went to the dealer and the parts guy i know there has been with ford for ever. he said ford did have a "After-after market" line just for ford. so if the car or truck didnt come with key less entry they would have a Ford line for "Aftermarket" parts. its a ford key less entry/alarm system. so with that said i still need a key fob ha
drill a small hole thru the corner near the ears ,doubt theres anything in the way there (open it to be sure)then slide a ring thru it .reattach to keychain .
what i done with one was to duct tape it to another fob on my keychain ,my sport came with 2 fobs ....one for ford keyless and another for a aftermarket system thats installed(got it this way).
i actually do have a extra fob here for a ford but its a 4 button ,has lock ,unlock, horn,trunk ,on it .says 315 mhz on the package . most ford fobs can be programmed by using a sequence of ignition starts i believe .
heres how
http://www.ebay.com/gds/How-to-program-a-replacement-ford-key-fob-remote-/10000000176305266/g.html
see the 4 button on the right in this link ,i have one brand new in factory seal bag .if you can use it email me .....joe3857@aol.com put key fob in subject .i dont check this board all that often anymore .12.00 shipped you can have it .it might need a battery ,i dont know its been in the pack a couple years .i have backups for most my fobs .
good luck .
oh and p-s:my aftermarket system is a black widow system ,look under your steering column area to see whats installed on yours .thats where my module is .i had to get the serial number off it then order a remote as it never came with one .
your fob kinda resembles my black widow one
also google is your friend
http://remotez4less.com/index.php/k...-remote-fob-new-fcc-id-goh-3bfm2497-0958.html
https://www.remotesandkeys.com/ProductDetails.asp?ProductCode=3085A
scroll down here they have one for 40 bucks
http://www.remote-superstore.com/webstore/index.php?page=20&cat_path=25&order_by=date&order_way=desc
says its a kia remote .at the second link theres info that says ford used "code"brand alarm systems in vehicles that needed keyless but didnt have it from factory .so you can look for a "code"brand fob .
you should really look around the truck for the module and see what you have there .
