squishyrock
- November 17, 2022
- Dallas
- 2016 Explorer XLT
I've added a heated steering wheel to my '16 XLT using the post by DanMc85 on the Fusions forum as a guide.
I was able to update the APIM via Forscan to enable the HSW button and it works, steering wheel heats up nicely. The other two settings mentioned by DanMc85 are IPC and FCIM. When trying to update the IPC, I get an error "Writing blocks failed - incompatible configuration". I assume this is because the HSWM has not been "master enabled" as mentioned by Dan. The HSWM does have a DTC: u2100:00 Initial Configuration Not Complete
But Forscan only shows a FCIMB and it's not available for programming. From what I could find online, the Explorer doesn't have an FCIM and it seems like the HVAC module would be the equivalent though can't confirm for sure.
Any one know where the HSWM is enabled via Forscan?
