Front axle shaft removal | Ford Explorer Forums
JW
Third Gen Collector
Sparks, NV
A Troop Of Gen 3s
What holds the front axle shafts in the differential? Does the cover need to be removed or can the axle be pulled without doing that?
shafts are held in with circlips, you do not need to remove the cover. With enough force they will pop out
