Front diferential | Ford Explorer Forums
Front diferential
omagasohe
Portsmouth, VA, USA
03 Explorer XLT
I apologies in advance, I can't search the forums, as since I'm in the middle of a move and my only access is at work and security setting won't let the results pop up.
I have a 2003 XLT V6 that the front differential has some horrible bearings in them, and I'm looking for part information so I can rebuilt it. Would anyone would be gracious to point me to a relevant post or at least give me a hand locating the parts, and a good reference in doing the rebuild?
Item Part Number Description
1 3T222 Pinion nut and washer
Disassembly Note
Assembly Note
2 4851 Pinion flange
Disassembly Note
Assembly Note
3 4859 Pinion oil seal deflector
4 4676 Pinion oil seal
Disassembly Note
Assembly Note
5 4859 Pinion shaft oil slinger
6 4621 Outer pinion bearing
7 4662 Collapsible spacer
8 1177 Axle shaft oil seal (2 req'd)
Disassembly Note
Assembly Note
9 1225 Axle shaft bearing (2 req'd)
Disassembly Note
Assembly Note
10 3C323 Cover bolts (10 req'd)
11 4033 Differential cover
12 355765 S Bolt (4 req'd)
13 — Bearing cap (part of 3010)
14 4204 Differential case
Disassembly Note
Assembly Note
15 3222 Pinion gear
16 4630 Inner pinion bearing
Disassembly Note
Assembly Note
17 4109 Pinion position shim
Disassembly Note
Assembly Note
18 4628 Inner pinion bearing cup
Disassembly Note
Assembly Note
19 4670 Oil baffle
20 4616 Outer pinion bearing cup
Disassembly Note
Assembly Note
21 4222 Differential bearing cup (2 req'd)
22 350672 S Ring gear bolt (8 req'd)
23 3222 Ring gear
24 1244 Differential bearing (2 req'd)
Disassembly Note
Assembly Note
25 4067 Differential bearing shim
Assembly Note
26 4211 Differential pinion shaft roll pin
27 4211 Differential pinion shaft
28 4215 Differential pinion gear (2 req'd)
29 4230 Differential pinion gear thrust washer (2 req'd)
30 4236 Differential side gears (2 req'd)
31 4228 Differential side gear thrust washer (2 req'd)
32 5386 Axle isolator bushing (2 req'd)
Disassembly Note
Assembly Note
33 5386 Axle isolator bushing
Disassembly Note
Assembly Note
