Lazzman
- June 27, 2005
- Massachusetts
- 1998 Sport 4wd- V6 Sohc
After a fuel filler neck replace, I was changing the inline fuel filter on my 1998 Explorer v6, sohc this afternoon and it was really tough to get off. I eventually was able to get it off and it was quite the struggle using the lisle fuel line tool.
The front metal quick connect fuel line that goes to the engine was exceptionally hard to get off and would not go back on snuggly, but I did manage to get it back on the filter and lock it in place.
Once I got the new Mann fuel filter connected I started the engine to test, I notice Niagra falls coming from the fuel filter quick connect.
I suspect the after the filter quick connect is damaged and needs to be replaced. The questions is how do I go about doing this?? I am sure it is a common problem.
This is the metal quick connect not the plastic one, I also noticed that the little black O-ring seal that goes inside the metal quick connect was broken as well, so that could also be the problem.
Anyhelp is greatly appreciated
