Fuel Injectors and Mass air 4.6l EB Turbo | Ford Explorer Forums
walkbk
Medford, NY
2007 Eddie 4.6l
I have a 2007 4.6l v8 Eddie Bauer ..
I plan on doing an STS rear mount turbo system running about 4-5 psi.
Can anybody tell me what size injectors/ Mass air flow sensor i would need.
Also do u think a fuel pump would be necessary or can i get away with the old one. Thanks for the help
Well I don't know about the fuel injectors, but I would go with a 2-3 bar map sensor. I ran 800cc injectors on my '91 sentra, but that was a built block and head running about 34lbs, and maxed out at 40lbs when I blew it. Thats a 4 cylinder though, hav'nt really worked on 6 or 8s I would get a higher output pump as well just to be safe, as well as a wideband, some form of boost monitering/control, egt sensor, fuel pressure regulator, maybe meth injection, theres a ton more, but thats if you don't want to waste money and just run 4-5lbs. I ran 15lbs on my camry, warped the head though...
