Fuel Pump Access Panel? | Ford Explorer Forums
Cashcrazy
TX
2011 Limited Explorer
Does the 2011 have an access panel for changing the fuel pump? I searched the forum and YouTube, but only found threads for fuel pump replacement on prior generations. I would greatly appreciate the link if anyone has found a walk-through for this procedure.
Sorry, according to the Haynes manual you have to drop the tank.
If you use the 'Search' function at the top right and you can limit the range of your search to the 5th generation Forum and or certain subforums. ;)
