Fuel rail question | Ford Explorer Forums
Fuel rail question
Greasegirl
Wenonah nj
2004 Explorer non sport
I have a 2004 Ford Explorer 4x4 I keep getting a check engine light every time I get gas. I ck the code and get fuel rail bank 2. Now I've replaced my fuel pump 3 times and of course in the three times that I've replaced it it's not an oem part now I find out that I have a fuel regulator underneath the manifold could this be the problem and not the fuel pump?
what is the actual code it is setting? that will help us to help you.
P0193 fuel rail pressure sensor high input
P0171 bank 1 lean
P0174 bank 2 lean
I think the p0193 is triggering the other 2 codes.
Yeah your issue is the fuel pressure / temp sensor on the drivers side fuel rail. The 2 lean codes indicate you also have a vacuum leak. Check for loose hoses going to the intake.
Loose hoses ok thank you. My other half didn't tell me that part hmmm never gives me the full and all details smh. We're attempting to take off the manifold this weekend He's looking to cheat it though by trying to slip his hand down under the manifold to get to it whether that can be done or not different story...his version not mine. But thank you for answering I appreciate all help...:thumbsup:
