PIU PIU Person
- January 25, 2025
- Texas
- 2017 Police Intercept Uty
Hello,
New to the forum and I have a new to me 2017 PIU bought at an auction.
The first time I took it to the mechanic, the engine code showed low fuel from the fuel tank pump. That got replaced and the mechanic showed me that the results showed the fuel was burning great. Long term and short term.
Couple of days later, the code showed O2 sensor Bank 1 sensor 1not operating at standard. I swapped it for OEM. No code for a couple of days.
Code light shows up again. Take to the mechanic and its showing the same O2 sensor not operating at standard. He checks the stats and the car is running rich but couldn't see any indication for why the code was thrown.
His theory is that the agency probably knew of the failing fuel pump and changed the PCM to compensate or override the low fuel rather than replace the fuel pump... and now that the pump has been changed the system is show it as to rich...
Does any here know if the PCM / Forscan can be changed in a manner that would compensate for low fuel and what I might look for to see if the fuel mixture is other than standard PIU fuel delivery?
Hope I am making sense to you...
