Gas lcd not showing correct fuel in tank? | Ford Explorer Forums
74sickness
Hi guys i am new to this forum and joined because i have a problem with my 2006 explorer limited, the problem is that i just put 30 litres of gas into my truck and now the lcd screen still says the same amount of gas as i had before. I dont know what to do is there a reset that you can do or something. Thanks a lot and i look forward to interacting with more of you.
Yes, on the center console just under the radio and HVAC vents there is a reset button. Press it down and the display should reset to 0 liters consumed. I am assuming that you are talking about the information center that can be switched between showing instantaneous fuel economy, MPG, fuel consumed, miles/kilometers left until empty, etc.
I had this issue once. We let it sit overnight and the next morning it worked correctly.
