This was the info I put onto the other post...
They will work on a '95, but2isses- the gauges light up green. Didn't matter for me because I already swapped everything to green in my Ex, didn't like the blue. Second, you will have to modify some of your gauges- some of the gauges on your cluster have resistors on the back, and if not swapped, will peg as gmac said. The voltage gauge is totally different, and uses a different needle. The new orange needle will not fit on the '95 gauge, so you'll have to make do. I just recentered mine for when the car is running, I wanted the orange needles, was too hard to see the white on white for my tastes. IIRC I had to swap my fuel and temp gauges with my '95 cluster and use the needles for the '01 on them. I also used the back of my '95 Cluster with the entire pop out gauge clusters so the lighting would work right. Some of the idiot lights will not line up- I had to repin my CEL, and the door ajar has to be done yet- the 'check fuel cap' light illuminates right now with an open door. But- I love it- looks good, and so much easier to read.
then due to dim lighting:
Al (and others) did you use the backing housing from your old cluster or the new one? Mine is very bright- just as it is in the pics... I think the clear plastic that the gauge faces mount on was different on the '95 and the '01- because the clear diffusers have to carry the light differently to the gauges maybe? I used the rear backing housing (casing) from the '95 and the white faces and clear things that they stick onto from the '01. May be something different in how the lights work and carry through.
I found my cluster at the junkyard...
The cluster wiring and light locations are different, you have to repin some of the wires- you'll have to look at the old cluster and see where the wire tape meets the connector, and relocate those wires to the new cluster locations.
Dig in! You'll love it...
