Glad to be aboard! | Ford Explorer Forums
Glad to be aboard!
crossbones
OKC, OK
2001 Sport Trac
So glad I found you guys, I hope you will be able to help with a leaking rear differential pinion seal.
welcome aboard
Welcome to Explorer Forum! It's not hard. Drop the drive shaft, drain your fluid, pull the yoke off, get the old seal out. (You may need a seal puller or might can get it out with a screwdriver and prying the lip up with CAUTION.) lube up the new seal, pop it in place and reverse the steps above.
