go to first new post: Hello Ford Explorer sport 95 from MX | Ford Explorer Forums
edg4rcia
Mexico, Guadalajara
'95 4X4 Expedition
Hello Guys, i have a explorer sport 95, and works well until two week ago, when de overdrive off light is blinking, and i dont know why if any body knows whats wrong, please, help me
thanks and congratulations for this great forum.
Like Brooklyn said- it is a problem with your transmission, do not drive your truck anymore until you get the codes and post them here. You can look at the thread below to see how you can retrieve the trouble codes from your truck:
CLICK ME
Then post the numbers that come off of your truck here and we can try to help.
bienvenido al foro edgar, saludos hasta la perla tapatia!
Hey Guys!!!!! Again I am on service after of large vacations... well I want to Tell you what`s happen with my Ex
I have unmounted the transmition (a large oddisey in old trucks) and I saw that some many gears are wasted, including the reverse bealt, overdrive belt, some washers and 2 soleinods are not working, the big thig blue (when the oil is cooled) like a pump should be repaired.
so I had called to one transmition specialist that will replace the wasted parts and will mount the transmition again on my EX
The specialist said that, this things are normals with old trucks and care due to the old components inside, that are wasted and some they works with frictions, so when you cange the transmition oil you remove the density the oil that allows the friction, is here when you have the fail!!!
I will explain the last one in spanish:
El especialista dice que, cuando tenemos una camioneta o carro viejo, hay componentes dentro, viejos, que tienen friccion o traccion con otros componentes que sufren desgaste, pero este desgaste genera una desidad pesada en el aceite, asi que sigue funcionana normalmente, cuando cambiamos el aceite por completo, se le quita la densidad al aceite y es cuando nos damos cuenta de estas fallas.
Thansks to all for you help and hospitality.
welcome
