Grease fittings on '94 Ex. | Ford Explorer Forums
snocross1985
Explorer-less
Stratham, NH
2018 Explorer XLT
Would anybody be able to tell me where all the grease fittings are on my '94? The ones that i found were one on each tie rod, one at the pitman arm, and one where the two tie rods meet. Are there any anywhere else that i missed?
When I grease the X (ours is a '92).. I do the following..
rod ends
pitman arm
ball joints
front-rear u-joints (if your drive shafts have them, you can get u-joints without grease fittings)
~Mark
On my '94 the orginal ball joints did not have grease fittings.
Tie rods and pitman arm is all they have stock as far as I know.
Our trucks don't come from the factory with grease fittings on the balljoints. You have to get some aftermarket balljoints (like Moog) to get the fittings.
Also from my experience they don't come with grease fittings on the driveshaft either. Again, that's something that you can add pretty easily though.
