stang99gtv8
- August 1, 2011
On my 97 AWD 5.0 Ex that I just picked up, I notice that it has a somewhat of a grinding-ish feel when accelerating, starts around 40-45mph. Don't feel it up to 40 mph. Also acts like it doesn't really want to go when starting off in reverse or turning at very low speeds. I see that while it has the same set of tires front and back, the front ones have more tread depth than the rear ones. Front ones probably have 20k miles on it while the rear have close to 100k miles on them.
My question is, would a difference in tread depth on an all time AWD like this cause it to have issues because of the difference in rotating speed from the lower tread depth in the rear? Could it be mismatching the speed that should be there and causing it to have problems adjusting, making it feel like it's trying too hard some times or kind of vibrating when going higher speeds?
I'm trying to determine if it's something in the drive line that's causing this or something such as the tire size being enough off to cause it to rotate faster in the rear, or if it's an axle or transfer case issue.
