brandan
- August 9, 2006
- Houston, TX
- 1996 Explorer XLT
I have a 1996 explorer 2wd xlt. The oil pressure, coolant temp, and odometer quit working over time. I purchased a used guge cluster from a junkyard to replace the broken one in the truck. It is out of a 1999 explorer 2wd xlt. Everything works properly except the coolant tempature guage reads really high. on a hot day it will get to the H and the check guage light will come on. In the morning or evening when its cool outside it will read 3/4 of the way up just below the H. I know the truck is not overheating so it must be an electrical issue plus I just changed the thermostat. Is there a different ohm rating for the sending unit on the 99 versuses the 96? Is there a way to test this issue or should I just try and find one out of a 96? Thanks for any help you can provide.
Brandan Orcutt
Brandan Orcutt
