hard shift from 1st to 2nd gear | Ford Explorer Forums
opeterson
Bremerhaven, Germany
2000 "Limited"-Edition
Hi there, this is a question from Germany.
My Model 2000 Explorer 6 Cyl, shifts hard from 1st to 2nd gear. Sometimes it's so hard that the TCIL is flashing until I switch the ignition off. All other gears are fine.
I changed ATF (MerconV) and filter, I cleaned valvebody, valves (except Bore 8 and 9 cause I can't get them out). All Solenoids have the right resistance and are klicking when put 12V to it.
I built in Sonnax Baseline Rebuild Kit. But that didn't fix the Problem (OK, the other gears are shifting faster, but thats all).
What about the intermediate servo or some sensors, cables etc.
Hope you can help.
Olaf
