Head Gasket Leak | Ford Explorer Forums
Head Gasket Leak
Got2Golf
Roswell, GA
2000 Explorer
I noticed an oil leak and while looking around I see it is the head gasket. I noticed that on the drivers side by the last plug (nearest the firewall) that a bolt is missing on the head....wierd. I suspect that the leak may be coming from here any idea on the sise of that bolt so i can replace it and clean up the oil to see if it continues? Thanks
You don't say what engine you have. But are you absolutely certain you aren't leaking oil from the valve cover and it's running down and looks like it's coming from the head gasket? I'm trying to think if there are any oil galleys through the block/head mating surface and I can't think of any.
You can't just throw any bolt in there. You need to go to a F/L/M dealer and buy a new head bolt. Using any other type of bolt is courting disaster.
Now, I hate to even mention this, but you may have a real ugly situation here. Take a piece of baling wire, or anything else you can use as a probe. Stick it down the head bolt hole and see how far it goes in before it bottoms out. Come back and let us know. Head bolts don't just fall out. I have never, ever seen one do that...and I've been working on vehicles since I was 14 years old...and I am one rusty, crusty ol' son of a gun! But they do break. You probably have a torque to yield fastener that gave up the ghost. I sure hope not though. Let's hope it just got left out for some dumb reason. Of course, maybe the block is stripped and the last person who worked on it just threw it together and sold it...
It is a 2000 Explorer 4.0L 6 cylinder. It may be coming from above and I took a few photos which I'll post for you to see. Thanks
Here are two photo's and to give you some perspective they are of the driver side of the engine along the plugs and the plug shown is the last plug nearest the firewall. The Red circle shows the bolt hole without a bolt and I have not had a chance to see how far until it bottoms out.
Any thoughts would be great.
Where are the links for the photos?
I can't figure out how to post the pictures on this site.... I have no patience for this so I'll have to get some to walk me through it...
Since you are not an elite member you cannot "upload" or "attach" pictures to your post. If you have the pictures on the 'net already you can take the url to the picture and put it between image tags..
when using image tags it will look like this.....
<img>http://www.domain.tld/picture.jpg</img> but use [ and ] instead of < and >
~Mark
