Headlamp moisture. | Ford Explorer Forums
Headlamp moisture.
trentrisner
Richwood OH
06 limited
I have an 06 limited and i have moisture in my headlamp. Help it looks so horrible
First take it off, dry the inside out with a blow dryer. Check and see if ther are any leaks aroud the outside of the housing, if so use some silicone(I would do it anyway-can't hurt). If not, condensation may be getting in from the bulb housing. Then get some insulation tape(home depot-AP/Armaflex from Carmacell, self adherhing-4 or 5 bucks) cut a 2x2 piece, cut a hole in the middle and make youself a washer so to speak. Should do the trick.
Drill a tiny hole (like 1/16" to 1/8") at the bottom of the plastic headlamp assembly.
i hate when that happens
