headlight problem on 2002 expl | Ford Explorer Forums
mario2208
Tennessee
02 XLS
I have a 02 exp ,,,the low beams do not work just went to turn them on and they didn;t come on everything else works high beams tail and park running lights could it be a relay i checked all fuses they where ok .
if a relay where is it located???
both low beams are out? I would suspect a fuse/relay problem. Look in either your owns manual or on the fuse boxes where everything is located (i.e. modules, etc.). I would suspect a fuse to be a problem. Fuses can be found on the left of the dash where the door meets. I would also look into the Fuses under the hood.
-Drew
Thanks I found it this morning cheap japanese bulbs both low beam bulbs blew at the same time ,,,stock bulbs back in all is well .
I used to buy thos import xenon bulbs for some time and they would last about a month before I had to change them. I finally gave up and just use the stock bulbs and they have yet to burn out.
