Headrest DVD Player not Working | Ford Explorer Forums
slickrock6
Plainfield
2011 Explorer LTD
I found that the head rest DVD player has no power. Any advice for both/either? Coincidently my camera failed as well. Says "Not available". (posted in Rearview Camera Problems )
Is the DVD system an OEM, dealer installed one? Did you check the fuse for it?
Yep, dealer installed. Don’t know where the fuse is located...
I'm guessing it would probably be in the cabin fuse box. You could call the dealer and see if there is a common available fuse they use for that installation. The other way is to check the fuse box and see if there is a fuse in it that is not identified in the Manual. If I were to go that route I'd check the engine bay one first since it is much easier to get at.
