heyok
- April 24, 2003
- Vancouver, Canada
- 2000 Eddie Bauer
I have the automatic climate control (is that what it is called? - you dial in the temperature). The system normally ramps the fan speed up and down automaically or you can adjust it manually. Tonight when I started the truck the fan was on high and I couldn't slow it down. I tried the control on the dash as well as on the steering wheel. Pushing OFF didn't help either, it just kept running. The heat and AC still seem to function because I can select a higher or lower temp and it blows warm or cold air as needed.
Wednesday I plan to go camping for ten days so I hope someone might have an idea of what I can do to fix this!
Thanks in advance,
Al
Thanks in advance,
Al
