Ok just found my diagrams if your looking into the end of the plug with the clips on left & right wider part to the bottom, The top Left #1(black wire, GRound) Next one down Black & Orange Logic Ground, Orange Transfer Case Motor Controll ClockWise, Yellow Transfer Case Motor Controll Counter Clockwise, Brown Electromagnetic Clutch feed, White & Purple Ignition Run & Crank feed(Fused), Black & White Battery Feed( Circuit Breaker), Dark Green & Lt. Green 20A. Maxi Fuse In Power Dist box...
Hope This Helps
~Drew~
