bri36
- December 12, 2004
- Michigan
- 2000 Explorer XLS
Hoping someone can help: My wife has the 2000 Explorer XLS with 54k miles, at 40k I carefully changed trans fluid and filter with no problems since, The car is not abused at all and kept in the garage. Anyhow the other day the car began to slip monentarily from 1st to 2ng gear, it does this as soon as you start to drive the car, while cold or warm. What happens is at about 25-30 mph the car rpm will rev up as if the car goes into neutral gear for about 1-2 seconds then will change into the next gear. It is def. slipping, but only in this gear, the fluid looks ok. not pure red but a brown red color, but not burned. I called a couple places was told a range of joy from new tranny needed to valve body gasket prob. needed. Wife said the o/d light was flashing, so I ran the codes with a real nice obd 2 coder, all systems passed, This is the 5r55w trans. If anyone has any ideas I thank you in advance for your response. Btw the car will slip like above on both the o/d on and o/d off modes. Thanks again.
