HELP..2003 Ford Sport Trac Windows/Wipers/Blinkers Not working | Ford Explorer Forums
logchamom
Farmerville, La
2003 Ford Sport XLT
2003 Ford Sport Trac - received damages in drivers side front and rear doors. Insurance replaced them with used doors. Doors switched out including components. Now the windows will not go down/doors will not lock - basically nothing on that control works - switch was tested and is good. All fuses were checked and none are blown. Now we noticed in just checking everything that the wipers do not work nor do the blinkers. Again fuses were checked - fuses are all good.
We own the shop that is repairing the truck, I have done this multiple times over the past 30 years and this is the first time all the normal things we look at are not the issue. If anyone has any suggestions or things we need to check can you please let me know.
I did read that there could be a problem of a pinched wire in the door boot - does anyone have any additional information on that?
Thanks!
