Help - A4LD Valve Body Version - 1994 Ranger Confusion | Ford Explorer Forums
fiftyfordfloored
Explorer Super Upper
Alpha, NJ
2005 Explorer 4x4 Limited
Pulled the A4LD out of my '94 Ranger (4.0L, Ext cab, 4x4) and I'm in the process of tear down and I've ordered almost all the parts I need... However, upon closer inspection of the valve body, it's casting numbers are not what I expected to find in a '94... 88GT-ACR and P88GT-7A10-ACR. I had thought the 91GT should be in there for a '94, but unfortunately its a Jasper unit. I guess my question is, did they play a game of mix'n'match, and are the valve bodies interchangeable? I can't seem to find much valve body information. To compound the issue, I had already ordered everything for the later unit including the solenoids. :(
As long as it is the 2 solenoid version it will work.
Anyone know a good place to find the updated version that doesn't cost $175? Or should I send the solenoids back and just use this valve body? I can't seem to find much information on the different year valve bodies, what improvements were made, etc...
Just want to re-verify that the solenoids are the same regardless of the valve body model. I have the 88GT valve body in my 94 Ranger but the solenoids I am seeing on eBay say they won't work with the 88GT and only with the 91DT and 91GT.
Buying them on eBay or Amazon is a bit scary. If anyone could recommend a reputable place online to get them, that would be great.
