9646gt
- March 11, 2008
- Fairbanks,Ak Eielson Air force Base
- 2003 Limited 4.6l
First off...the vehicle was fine as far as I remember during the summer...I am stationed in Fairbanks,Alaska right now and this is the vehicles second winter here. I don't remember having any major issues last year with the vehicle being parked inside over night...however this year the new car is being garaged over the winter so the Explorer is outside all the time (2003 Explorer limited 4.6l ) where the temps can become as low as 60 degrees below zero at the most extreme times but lately the coldest it has seen was -25 or so. I should note that I have battery heaters oil pan heater and block heater all installed and plan to install a tranny heater this weekend. Now I am having CRAZY electrical issues.
My cruise control will not turn on sometimes and functions perfect other times.
I went to get out of the car a few times and the radio power staye don where it normally turns off when you open the door. It stayed on even after opening and closing all doors but the dome light and door ajar indications were gone.
My ABS and Brake indicator lights are staying on at about 15mph and faster and alot of times will radomly go away as I start to brake once I get down to about 15mph or slower then will come back on and sometimes even alternate from both lights to just the ABS light. I need abs with the horrible road conditions!
My wife tried to goto town tonight and said the seat would not move back when ignition was turned off then I guess it started going back and kept going till it made a clicking noise a few times or something.
My rear driver side window will randomly not respond up or down
My from pass side window switch lights went out and the witch no longer functions but the door lock part does. The window works fine from the driver side switch.
I can't think of anything else right this second but I am sure there is more. Where do I start?!? There has been no check engine light on. I CAN'T take it to the dealer here as there is only one and it's a HUGE monopoly.
Please help me out guys
I am so affraid of becoming stranded where it can be a life or death situation in a place like this!
