- August 26, 2004
- West Virginia
- 1993 2dr
week or so back I was on my way to a trail run and noticed the engine temp was running warmer than normal. on the trails the engine temp continued to rise along with the trans temp. got home and the overflow tank was boiling over so i changed the thermostat and filled/purged the coolant system. the truck sat until yesterday, took it to gas it up for a big trail ride today and the same thing happens. when I left my house the overflow was empty, get home and the overflow is filling up to the brim and bubbling violently.
talked to a few friends with shops and knowledge yesterday, a couple mentioned a plugged radiator or bad water pump. well the water pump isnt leaking or making noise, neither is the fan clutch.
several poeple mentioned a cracked head gasket.. with compression blow by forcing the coolant back through the system. sounds possible, i just have a hard time believing that since the truck never went out of the normal range. will be doing a compression check as soon as i fully wake up.
any feedback? ideas? things for me to check? let me know, cause i am ticked lol first big trail run of the year, i have a full tank of gas, but cant go!
