HELP!....Installed rebuilt a4ld..transfer case prob? stuck in gear..no rev.. | Ford Explorer Forums
ragga
Ok, 94 explorer...newer a4ld...bell housing was 90, marked with 2004 date in sharpie inside housing...
I finally finished rebuilding my a4ld, changed everything out bushings, washers, clutches, steels, TC, servos for OD and Intermed...this was my first rebuild, but I thought everything went well...I reinstalled tranny, bolted everything up, transfer case slid in, the only thing I didnt get installed like I wanted was locking clip on speedo cable on transfer case, but cable seemed to be inserted correctly. I added 4 qts, started for a second, added 4 more, and started checking level...but I was parked on a slight incline. I ended up putting in almost 10 qts.
When I started engine, it was like brakes were stuck on....couldn't roll in neutral. Only had forward movement, although it seemed like it went through gears, idle changed.... had a high tinny sound like something turning from area of transfer case....leaking fluid from bottom of transfer case between tranny and transfer case.
Edit-OK... I often am reminded that I am an idiot mechanically...I am assuming this leak is from not installing a gasket between tranny and transfer case? I don't remember there being one when I removed it...but maybe it was stuck to extens housing and I cleaned it off later.wasn't in master kit...going to get gasket, reassemble, and rediagnose I guess.....
P.S> OK I cannot find a gasket at auto parts store...not sure if it's supposed to have one or not...I'm thinking a little permatex couldn't hurt regardless?... I disconnected rear drive shaft at diff, tiewrapped it hanging from exhaust hanger so I could roll veh...still wouldn't roll... transfer case was in a bind..front shaft bound also...after I freed that up veh rolled back into space at least... going to do pressure test tommorow with guage and see what I get....
I am going to remove driveshaft from transfer case so I can roll veh back.....and I assume I will be removing transfer case. When I started veh it also was in 4Whigh... not sure if I left it that way or not, but I may have since my book says to put transfer case in gear when checking fluid level, may have checked it before I pulled tranny and left it in 4WH...
Anyone have any suggestions?
Thanks for any help....
Ragga
