- February 16, 2001
- 43°48′48″N 91°13′59″W
- 91 4 do'
So several of you know that I am putting my lift in and also know that I have a track record for showing up to offroad in a not so trail ready truck. Well my lift went smooth, my front end is another story. Before Attica, I had an axle shaft replaced, them mechanic did not look at the seal. I knowing no better than to trust my mechanic took it and went wheelin. Well as is turns out my diffy fluid was replaced with dirt and mud, end result when we looked at everything cause it was making a noise is a trashed front end.
I went to the mechanic and he got in my face saying the job was to change the shaft, not pull the front end out, so he is not responsible and if I think I am then I am nuts cause I have 7 years on this front end. Well what do you think?
Also I want either a used 3.73 front end to stick in there,
or
my other idea was to get a Detroit true-trac and 4.10 gears but I dont want to spend this cash yet but it is tempting with it all out in the open. Dre I know you have a front end
Help
Help
Help
Dan
or
Help
Help
Help
Dan
