Help me find a grounding spot inside my cab - 04 Explorer | Ford Explorer Forums
Stimpy911
Michigan
2004 Ford Explorer XLT
I am installing a ground bus bar from Blue Sea and I am planning on running an 8 gauge wire from the bar to a grounding spot somewhere on my vehicle. Is there a good place inside my cab to run the cable too? Attached to the bar will be the grounding wires from the following equipment.
Whelen Mini Edge 9000 Strobe Lightbar
Speed Tech Lights dash light
Whelen Siren
6 position switch box.
My positive wires will be connected to a fuse block. I just need to find a good grounding spot inside my cab otherwise I will have to run the 8 gauge wire to a chassis point in my engine compartment.
My ground bar and fuse block are located inside my cab attached to my radio console.
Thanks for your help.
