ELeBlanc
- December 12, 2016
- Location
- brooklyn ny
- brooklyn, ny
- 1997 Ford Explorer
I'm not mechanically inclined but a diligent reader and occasional poster here. My vehicle is 1997 Explorer 5.0 AWD 90k. Skipping the issues but my mechanic told me he was going to replace steering column bushings. I get the car back and if I have the door open with key in I get a warning tone - ok... If I remove the key with door still open I still get the warning tone - now I don't know if that is Ok or not Ok. I know I didn't used to get any warnings unless key was in ignition. So the behavior is definitely different and I think wrong but I' not sure... Lastly, assuming this new behavior is wrong, what could they have done when they had the steering column open and down?
thanks.
Been debating whether to keep this and invest some money or move on. Being 23 years old and in northeast it has underbody rust... On lift definitely rust - mechanic thought shocks and replace leaf spring shackles in back. On the lift we saw likely a rear main seal leak but not a downpour and one front axle seal also leaking. Mechanic suggests not investing much money and looking for something else...
A year ago I brought it to a mechanic in PA a year ago and he was afraid to lift it due to frame rust. I had to tell PA mechanic that my NYC mechanic has never hesitated and obviously never had a issue lifting it so PA guy did lift it with no issues.
thanks in advance
Techexchange
thanks.
thanks in advance
Techexchange
