nitro71
- April 30, 2009
- Spokane WA
My tranny is getting very hard to shift into every gear. At a stop today I couldn't get it into gear for about 20 seconds. Something is going **** up. It also seems like my clutch engagement point is moving towards the end of the clutch up stroke. From searching posts it seems like the culprit is probably the slave cylinder or some bearing catching on the shaft? Can you replace the slave cylinder with the tranny in the vehicle(3 inch body lift)? Or is it more likely its that bearing(if someone knows it's name chime in!)?
Wheeled the X hard today and it was rock solid. Couldn't be more happy with it's off road performance.
