JohnB0
- July 29, 2020
- Greenville SC
- 2007 Ford sports trac
I took my 2007 sports trac to the shop today for a leaking rear main. The mechanic called later and showed me the flywheel which had some teeth with a slight grind on them. He suggested replacing it with another he had which he said was the same flywheel. On the way home, I drove it about 30 miles and have several concerns. In the dash, there was a engine block and small wrench icon on. The speedometer, trip meter and other information did not appear as it had. It also showed low fuel although it was full of gas. Additionally, the tranny did not shift as before with a longer time needed to shift. It also seems that when I took my foot off the petal, it slowed sharply. The engine is the 4.0 and had no kick and did not have the power compared to before. Does anyone think the flywheel could be the source of the power issue? Another oil leak was present but do not think it is the rear main. Earlier the upper and lower seals were replaced. I would appreciate any thoughts any of you may help that I can discuss with the mechanic tomorrow. JohnB
