blue_goose
- November 18, 2006
- WY
- '02 4x4 4.0 200K
So I am in the process of replacing the rear diff bearings and I can't even get into the diff! I took out the 2 bolts holding the cover to the frame along with 8 other 1/2" bolts holding the cover to the diff and no matter what we do it will not budge. I stopped after I broke off one of the tabs (not sure if that is the correct term) when hammering a chisel between the tab on the diff housing and the other one in the cover. I have fluid very slowly seeping out of the seal. I am at a loss of things to do-I have never seen this happen before. it is not hitting the frame in the back when i try to get it off, hitting it with a copper hammer dosn't do anything and I'm not about to hit it harder, trying to wedge a hammer a shim-type thing between the cover and dif isn't happening..... Any ideas?
