filmfilm01
- July 8, 2006
- Albuquerque,NM
- 00 limited
My rear wiper works sometime,and rests for days,seems just depend on what the weather is!
I search the internet including this forum. The broblem maybe:
1) relay. This is the easiest case to figure out if you didn't hear the motor clicking noise.
2) Bad ground wire connection (doesn't make sence since most of the case, you can hear the clicking noise)
3)motor design problem. I prefer this explaination.
Actually, I even removed disassembled my rear woper motor and checked the structure inside: grease falling down on the electric brush causes the current disconnected, when I cleaned the grease over there and install the motor,it works, but several days it stops again( still the same problem).
Then I tried to buy an OEM part from autozone . it works but stop working someday and then who knows sometime it works again.
Shaking the wiper arm may help, probably this may help remove the grease and make a good electric contact.so the problem may arise from bad design.
Somebody's post on the web said that the motor from Advance Auto parts can solve the problem. is there any feedback on this aftermarket motor ????
This is not critical problem, but make me uncomfortable.I need a solution to solve this.
Thank you for your discusstion and tips.
