Kirby N.
- February 6, 2001
- Colorado Springs, CO
- 1991 Ranger
Any help would be appreciated. I swapped out my a4ld after a blowing a few a4lds for a manual. The swap went smooth and I have been driving it for 8 months or something. The only problem is that it is difficult to get the tranny into gear from nuetral when the truck is
1. Warmed up
2. At a dead stop
It will go into gear fine if I am rolling or if it is right when I start it up.
In the swap I replaced all the slave/ master cylinder hardware and plumbing so I do not think this is the cause.
I used the used clutch from the donor vehicle because it looked to be in good shape, I also used the flywheel and pressure plate from the donor for the same reasons.
I am completeing my swap by putting in a manual tcase too in the next few weeks and I would like to take care of the shifting problem if it is simple.
Please help! Thank you!
Kirby
1. Warmed up
2. At a dead stop
Kirby
