EB4X
- December 28, 2016
- Orange county, Ca
- 95 Explorer 4X 4.0 ohv
I started disassembling instrument panel to get my odometer working again (common broken plastic gear) and shift indicator clip disconnected....I was on youtube and other step-by-step webpage and neither addressed this....it just unclipped but zero slack AND WAY TOO TIGHT of spot to get hand up in there and guide properly back into hole/slot...tried needle nose and just not doable due to tension of cable/position etc.......not sure if safe/easy procedure to unhook cable and proceed with repair since I got everything else apart.....anybody else deal with this?? Input...? .....the cable going down to junction point - apparatus bridging to shifting to trans is completely covered by metal housing...short of going through that nightmare of removing all that I guess I'm hating life....it still shifts without binding of cable FOR NOW...but I'm guessing left like this will create problem shortly down road....
See pic....
See pic....
