help sunroof won't close and the radio won't turn on! | Ford Explorer Forums
9646gt
Fairbanks,Ak Eielson Air force Base
2003 Limited 4.6l
Ok First of all I already checked my two 20a fuses under the dash for sunroof and radio and both are good. My sunroof is stuck open and my radio will not power on. It will load and eject cd's and show the time if I hit menu but the radio with not come on when I hit the power button. Disconecting the didn't help either! I have no idea what to do. I just changed the batter a few months ago because the washer fluid sprayed on it's on and the 4x4 light flashed as well as the abs light. Then when you turned the explorer off the radio wouldn't turn off and the seat kept moving. It's an 03 Limited 4.6L with 95k on the clock. Any help guys?!?
