help!!! tranny leak dont know were | Ford Explorer Forums
gabeg420
pennsauken nj
1992 ford explorer eb
i got tranny fluid leaking off my i guess it the shift linkage maybe it on the driver side it looks like some type of shift linkage but i always have tranny fluid on it when im parked
Their's a little seal that goes between the shift shaft and case, that would be my guess if your linkage is wet.
how do i go about changing that by takin the trans pan out would i be able to check it that way
You have to pull off the pan, the pin in the case, Z link, and the lock nut on the back of the shaft. The seal could be removed with a screwdriver, and carefully reinstalled with a socket, and a hammer.
How does the pin come out?
